• Compact SUV has emotional, powerful design and high level of functionality
  • Infotainment and assistance systems from the full-size class
  • Engines from 85 kW (116 hp) to 140 kW (190 hp), quattro drive
Audi is revealing the new Audi Q2* at the Geneva International Motor Show. The compact SUV is an urban-type vehicle for everyday driving and recreation, uniting a progressive design with a high level of functionality. Connectivity, infotainment and assistance systems are on level of full-size class.
“In the Audi Q2 we have developed a distinctively geometric form language with model-specific design characteristics. The car exhibits an independent character within the Q family,” says Audi Head of Design Marc Lichte.
Rugged look
Audi Q2
The result: a powerful SUV that shows a lot of vertices and edges. At the front, a strong image is created by the Singleframe grille in octagonal design that is positioned high as well as large air inlets. Especially eye-catching is the low roof that descends and merges into the C-pillars with color offset blades. This contrast accentuates the sportiness of the Audi Q2. The rear body terminates in a dynamic way with a long roof spoiler and a diffuser that has an underbody-protection look.
In a side view, the high shoulder line is especially eye-catching as are the concave flanks in the door area. The latter emphasize the wheel housings and thereby the quattro character of the compact SUV. The vehicle measures 1.51 meters (5.0 ft) tall and 1.79 meters (5.9 ft) wide. The overhangs are short with a vehicle length of 4.19 meters (13.7 ft) and a wheelbase of 2.60 meters (8.5 ft).
Technology from the full-size classAlong with the optional Audi virtual cockpit and the head-up display, the driver assistance systems for the Audi Q2 also come from the full-size class – including the Audi pre sense front that is standard. The system recognizes critical situations with other vehicles as well as pedestrians crossing in front of the vehicle, and if necessary it can initiate hard braking – to a standstill at low speeds. Other systems in the line-up: adaptive cruise control with Stop & Go function, traffic jam assist, the lane-departure warning system Audi side assist, the lane-keeping assistant Audi active lane assist, traffic sign recognition and parking and cross-traffic assist rear.
Highly connected
Audi Q2
The Q2 is equipped with a standard MMI screen that is positioned high on the instrument panel. The infotainment system can be operated by a rotary/push-button control and two buttons on the center tunnel. When MMI navigation plus with MMI touch is ordered, the user also gets a touchpad on the central control element. In addition, the system can be conveniently controlled by natural language operation and the integrated MMI search. A Wi-Fi hotspot enables surfing and streaming with mobile end devices. Furthermore, customers can use MMI touch to query the online services of Audi connect. The flat rate data plan required for this is included thanks to the SIM card (embedded SIM) that is permanently installed in the car. It also permits roaming in most European countries. Cell phones with iOS and Android operating systems are integrated into the car via the Audi smartphone interface. The free Audi MMI connect app enables online media streaming and transfer of a calendar from a smartphone to the MMI. The app for iOS operating systems also has the myAudi destinations function. It makes it possible to send the data of a desired navigation destination from any app to the MMI navigation plus system. The system then uses it for navigation.
Simply functional
Audi Q2
The Q2 fulfills fundamental expectations of an SUV with a high entry, good visibility and a large luggage compartment (405 to 1,050 liters (14.3 - 37.1 cu ft) of capacity). The highlight is that the driver’s seat position is sporty and low in relation to the steering wheel like in an Audi sedan. Optional practical solutions are available such as a power tailgate and a three-way split rear bench backrests with cargo through-loading.
Individual customizationThe Audi Q2 is as individual as its drivers – inside and out. Many equipment packages, exterior colors and expressive colors for interior trim and seat upholstery allow plenty of creative space for personal configuration. One option is the LED lighting package, in which the interior is staged in a particularly attractive way with illuminated trim elements.
Drivetrain and chassis
Audi Q2
The Q2 is launching with a selection of six different engines. Along with a 1.0-liter three-cylinder TFSI, two four-cylinder gasoline engines are being offered with 1.4 and 2.0 liters of displacement. In addition, three four-cylinder diesel engines are available with 1.6 and 2.0 liters of displacement. Their power output ranges from 85 kW (116 hp) to 140 kW (190 hp). As an alternative to the six-speed manual transmission, Audi also offers the S tronic dual clutch transmission with seven speeds for all engines. In the case of the top TDI and the 2.0 TFSI, a newly developed dual-clutch transmission is used, which has a new type of oil supply and reduced friction. Both engines may also be combined with a quattro permanent all-wheel drive system as standard equipment. Installed at the rear on the front-wheel drive versions is a semi-independent suspension, while the quattro models have a four-link suspension. Progressive steering is standard in all versions. It varies the steering gear ratio as a function of the steering input; the ratio is made more direct with large steering movements. Adaptive dampers are available as an option, as is the Audi drive select system with which drivers can set an individual characteristic for their Q2.
Market launchThe Audi Q2 launches on the European market in autumn 2016. Ordering begins mid-year for the compact SUV.
For further information, visit the Audi Media Center at  www.audi-mediacenter.com/en/geneva-2016  and the online magazine ‘Q2 illustrated’ at  https://www.Q2-illustrated.com/en .
