The lifeline of your engine is oil. Oil circulates through passages in your engine and lubricates moving parts, cutting down on friction. In order to keep this oil clean, it passes through a filter which removes harmful contaminants. The engine on the 1.8T and 2.0T generation 3 TSI turbo engine is equipped with a filter inside a fragile plastic housing. Each time you perform an oil change this housing needs to be removed. Unfortunately the plastic filter housing becomes brittle over time and often cracks during oil changes which are performed regularly. Constructed of billet aluminum, the USP Cool Flow housing is far stronger than the factory plastic housing. Not only is the Cool Flow housing stronger, but it also incorporates cooling fins to help cool engine oil as it passes through the filter and housing. Installation is straight forward and requires no special tools. This is a must have for every A3 or S3.
  • CNC billet aluminum
  • Lifetime warranty
  • Uses OEM oil filter and o-ring
Available for:
  • 2014+ Audi 8V A3 1.8T and 2.0T
  • 2015+ Audi 8V S3
Product
Installed 1
Click here for more information
