Unitronic is pleased to announce the official worldwide release of its Performance Software for the C7/C7.5 RS6/RS7.  With baseline figures and data collected, Unitronic interprets the data and adjusts the engine control parameters for optimal performance. Research and development of Unitronic’s Performance Software continues with further dyno and track testing, while closely monitoring running conditions through live high-speed data logging tools, and further optimizations are made to ensure maximum performance is achieved, while maintaining complete OEM-like reliability and drivability; increasing throttle response, and improving overall fuel efficiency*. Unitronic’s Performance Software is programmable directly through the OBD-2 port and is UniConnect+ compatible. Within minutes you’ll be enjoying a total night-and-day driving experience.
UniConnect+
UniConnect+is Unitronic’s End-User Programming and Diagnostic Interface, which gives its Clients the freedom to flash their Engine Control Unit (ECU) and their Transmission Control Unit (TCU) from the comfort of their home or garage. It is no longer necessary to schedule an appointment at an Authorized Unitronic Dealer to have your performance software installed, removed, upgraded or reflashed. UniConnect+ empowers its Unitronic Performance Software Clients with the freedom to tune their vehicle at their will.
Unitronic’s Stage 1 and Stage 1+ Performance Software are both designed for otherwise complete stock vehicles, requiring no supporting hardware modifications and provides a great entry-level upgrade. Stage 1 is optimized for 91 OCT/95 RON fuel, producing 671 HP/652 lb-ft TQ.
Unitronic-Ecu-Upgrade-C7-RS6-RS7-Stage1
For Clients with access to 93 OCT/98 RON fuel, Stage 1+ takes advantage of higher grade fuel, producing an increase in output to 691 HP/655lb.-ft TQ.
Unitronic-Ecu-Upgrade-C7-RS6-RS7-Stage1plus
2015 Golf R Pricing Table v1_1
Additional Features
  • Improved throttle response
  • Factory Failsafes Retained
  • Engine Temperature Protection (rev limit based on engine coolant temperature)
  • Optimized Responsiveness and driveability
  • Speed Limiter Removed
  • Power delivery perfectly optimized throughout the power band
  • Increased fuel economy
Available Soon
  • Stage 2 Performance Software (Optimized for Unitronic Downpipes)
  • Unitronic Downpipes
Applications
C7 Audi RS6
C7 Audi RS7
C7.5 Audi RS6
C7.5 Audi RS7
*Subject to ecu box code availability.
For more information, be sure to contact your local  Authorized Unitronic Dealer  to get yours now!
Locate
*May not be available for all ECU IDs. Contact your local Authtorized Unitronic Dealer for more information.
