Audi Forum - Fourtitude banner
1 - 16 of 16 Posts
Registered
Joined
Discussion Starter #1 (Edited)
All prices include Free Ground in the Lower 48
FST Steel Billet Flywheel fits B5 S4 RS4, C5 A6 & Allroad Single Mass Flywheel. 28 pounds with starter ring gear,Includes replaceable friction surface.Compatible with RS4 pressure plate and sprung hub clutch disc. Comes with 8 Flywheel ,6 pressure plate bolts and OEM INA pilot bearing pre-pressed.
2.7T FST STEEL BILLET L/W Flywheel $599.95 Shipped Ground
2.7T Kits with 28 pound Steel Billet Flywheel.
FST Steel Billet Flywheel fits B5 S4 Single Mass Flywheel. 28 pounds with starter ring gear,Includes replaceable friction surface. OEM LUK S4 pressure plate,OEM LUK Sprung Hub clutch disc, OEM INA release bearing Comes with 8 Flywheel ,6 pressure plate bolts and OEM INA pilot bearing pre-pressed.
2.7T FST STEEL BILLET L/W Flywheel W/ S4 Clutch Kit $899.99 Shipped Ground
FST Steel Billet Flywheel fits B5 S4 & RS4 Single Mass Flywheel. 28 pounds with starter ring gear,Includes replaceable friction surface. OEM LUK RS4 pressure plate,OEM LUK Sprung Hub clutch disc, OEM INA release bearing Comes with 8 Flywheel ,6 pressure plate bolts and OEM INA pilot bearing pre-pressed.
2.7T FST STEEL BILLET L/W Flywheel W/ RS4 Clutch Kit $1029.99 Shipped Ground
FST Steel Billet Flywheel fits B5 S4 & RS4 Single Mass Flywheel. 28 pounds with starter ring gear,Includes replaceable friction surface. OEM LUK RS4 pressure plate,Clutchnet Kevlar Sprung Hub clutch disc, OEM INA release bearing Comes with 8 Flywheel ,6 pressure plate bolts and OEM INA pilot bearing pre-pressed.
2.7T FST STEEL BILLET L/W Flywheel W/ RS4 Pressure Plate, Kevlar Disc $1199.99 Shipped Ground
Clutch Kits OEM and Performance
LUK S4 Clutch Kit Includes S4 Pressure Plate, S4 Sprung Hub Disc and INA Release bearing.
Luk S4 Clutch Kit $335.95 Shipped Ground
LUK RS4 Clutch Kit Includes RS4 Pressure Plate,RS4 Sprung Hub Disc and INA Release bearing.
Luk RS4 Clutch Kit $469.99 Shipped Ground
South Bend Clutch Kits W/O Flywheel
$680.21 SBC Stage 1 Kit 240MM Organic Sprung hub Clutch disc, Pressure Plate equal to RS4 Clamp force & OE release bearing. Rated @ 400 Torque.
SBC 2.7T STAGE 2 DAILY KIT
$760.75 SBC Stage 2 Kit 240MM Kevlar Sprung hub Clutch disc, Pressure Plate equal to RS4 Clamp force& OE release bearing.Rated @ 475 Torque.
SBC 2.7T Stage 2 Kevlar
$1,033.92 SBC Stage 3 OFE Kit 240MM OFE stage 3 Clutch disc,Pressure Plate equal to RS4 Clamp force & OE release bearing. Rated @ 525 Torque.
SBC 2.7T Stage 3 OFE KIT
$699 SBC Stage 4 OFE Kit 240MM OFE stage 4 Clutch disc, Pressure Plate equal to RS4 Clamp force & OE release bearing. Rated @ 600 Torque.
SBC 2.7T Stage 4 OFE KIT
$549.95 LUK Dual Mass Flywheel fits B5 S4 RS4, C5 A6 & Allroad OEM DM Flywheel. 32 pounds with starter ring gear,OEM INA pilot bearing pre-pressed.
2.7T LUK DM Flywheel
Visa Mastercard Discover and American Express can be accepted via Paypal without registration.
California residents will be charged 7.75 % sales tax.
http://www.FourSeasonTuning.com
The current site only has a fraction of the parts listed that we carry.Please contact us if the items you seek are not on the site. Competitive pricing, Fast shipping, If you see a lower price let us know, chances are we can work with you.
Questions at 714-997-5842
Email is better than IM
sales(AT)fourseasontuning.com*
Thanks for looking.
James
Registered
Joined
Does a lightened flywheel eliminate the "rev hang" when clutching in between shifts in a B5 S4? if so how much lighter does it need to be for the revs to drop as they should?
Registered
Joined
Registered
Joined
Discussion Starter #9
Off hand I don't recall if the S4 has a clutch switch. For example a VW Mk4 has a clutch switch, when pressed, it will disable the soft return in the throttle body.
This allows for a faster closing of the throttle valve, a defect switch or wiring will keep the revs hanging.
1 - 16 of 16 Posts
