FS: 2004 Audi RS6 - Toronto, Ontario, Canada
3K views 1 reply 2 participants last post by  A.C.
#1 · (Edited)
2004 Audi RS6 Blk/Blk/Carbon Fiber
Price: $21,000CAD ($17,000 USD)
Body
- perfect shape, never any accident, no dents, no rust
- never winter driven
- I had it undercoated regularly (www.rustcheck.com)
- both mirrors are in perfect shape and have no stains (I got new ones last year at $400 each)
Interior
- no dents, cracks or rips, the interior is in very good shape and I have both OEM summer and winter mats
- sound system is perfect and I also have the iPod/mini-jack connector
- I have two remotes for the car
- A/C climate control works perfect
Tires/Wheels
- The rims on now are OEM RS4 19in rims and I installed new Yokohama summer tires two months ago
- I have the original 18in rims (with the car's VIN #) and they have new winter tires on them (never used)
Engine
- no problems at all, no check engine codes (I have a VAG-COM)
- the car has a stage 1 chip
- no oil leaks, boost leaks or vacuum leaks
- in Aug 2017 I installed the following: iridium spark plugs, OEM coil packs, two OEM MAFs
- I install new PCV valves every year to prevent oil leaks
- I only use Royal Purple 5w40 with OEM oil filters every 7k-8k
- I change all the filters (engine/cabin) twice a year
- I changed the fuel filter at 160k
- the last timing on the car was done at 150k, I already purchased the complete kit purchased for the next service
- I installed new engine mounts last spring (http://www.apikol.com/index.php/products/engine/stern-s4-rs6-pro-mount-motor-mounts.html) and I also purchased but didn't install yet (https://store.034motorsport.com/snub-torque-mount-street-density-b7-audi-rs4-c5-audi-rs6.html)
- I also installed the Wagner turbo hose kit
Note: I regret replacing the engine and transmission mounts, the old ones were ok I was trying to be preventative because of the mileage of the car, the new ones are good but I wasted money.
Transmission
- the transmission shifts perfectly and it has no codes and no leaks, I had it rebuilt over a year ago at http://www.torautotrans.com/ and I got an upgraded torque converter and upgraded internals (I have the invoice)
- I installed just a few weeks ago (https://store.034motorsport.com/tra...ine-tiptronic-b6-b7-c5-audi-a4-s4-s6-rs6.html)
Suspension
- OEM except for https://www.hotchkis.net/product/20...-sway-bar-set-from-hotchkis-sport-suspension/ which I installed one year ago
- no leaks in the suspension, car had the DRC recall done in 2012
- control arms are in good shape
- last alignment was about one month ago when I installed new tires
- there is 0 play in all four wheels, no loose bushings/tie-rods/ball joints
Brakes
Front - I just installed two months ago brand new rotors and pads (Zimmerman rotors, Stoptech Street pads) and I also bled the whole system, the brakes are perfect
Rear - new rotors were installed one year ago, and I just installed new pads (StopTech Street) two weeks ago and of course also bled the rear lines
See link below for pics:
You have insufficient privileges to reply here.
