Well I finally realized 5 projects is too many. You can see me dying inside as I cleaned it up to take pictures today. I’d like to sell this as a package and see someone finish it.
2004 A6 4.2 64,451 miles Automatic
I replaced the cruise control stalk, did the transgo upgraded pressure regulator, new transmission fluid, phenolic intake spacers, timing belt was done at the dealership, started to swap out the power steering fluid but it could probably use another flush, and probably some other small things I’m forgetting. I was going to six speed swap it but that transmission is now the spare for my S6. I also have cam seals which don’t need to be done but I kept the parts, new fuel filter and throttle body coolant bypass kit.
Might need a passenger side valve cover gasket and is dying to be lowered.
What I have for parts not included in the price;
Apikol front snub Mount 20
034 Aluminum subframe bushings. 150
S6 Aluminum subframe. 250
Brada BR5 18x9 wheels 1500
Aero speed lug nut’s 50
Extended studs 40
Extended studs 40
