Seasonal allergies can be crippling, and those who suffer from them know this all to well.  For the affected, sleepless nights, difficulty breathing and general discomfort and much more are all but guaranteed for a few weeks, but thanks to Audi's new cabin filter, next year might not be quite as bad.  Specifically designed to remove harmful gasses and "neutralize a majority of all allergens", the new cabin filter will come in two different versions- one which reduces allergens through a bioactive substance called "polyphenols", and the other which uses a modified protein structure to achieve the same effect.
Apart from giving sweet relief to those who suffer from allergies, Audi's new cabin filter will also improve the overall air quality within the vehicle by using a multi-layer filtration system.  Independent tests performed by SGS Fresenius and Fiatec GmbH have  validated Audi's claims, and the new system will launch this June in the Audi A3, Q3, TT and A1, as well as Audi's Q2 at launch.
Get all the details below.
  • Active substances in filter reduce allergens
  • Additional layers against fine particulates and gaseous impurities
  • Use in Audi A1, A3, Q3 and TT from June; in Audi Q2 at launch
Beginning in June 2016, compact Audi models will roll off the assembly line with a new filter in the air conditioning system. This not only removes fine particulates and harmful gases from the air, it also neutralizes a majority of all allergens. With the new filter, Audi is setting a new standard worldwide in the premium compact segment.
A new air conditioning filter will be used in the Audi A1, A3, Q3 and TT model series beginning in June. The new Audi Q2 will be equipped with the filter at market launch. Customers can also have their cars in the respective model series retrofitted with the new filter as part of their regularly scheduled service intervals.
The filter is available in two versions, each of which comprises three layers. They work differently, however. What makes them special is the new outer carrier layer, which now features an additional anti-allergen effect. One variant reduces allergens by means of plant-derived, bioactive substances called polyphenols, which attach themselves to the receptors of the allergens. The other uses a modification of the protein structure to achieve the desired affect. Independent tests by specialized testing institutions such as SGS Fresenius, which investigates the allergenic properties, and Fiatec GmbH, which tests the filter properties, confirm the high effectiveness of the new Audi filters.
The two layers present in existing filters also make a significant contribution to the high air quality in the interior. The filtration layer made up of special microfibers removes even the tiniest of particulates from the air. Gaseous impurities are trapped in the activated carbon layer.
A comprehensive measurement series documents the high effectiveness of the filter system. The arrangement of the layers ensures outstanding separation performance and conditioner air throughput over the life of the filter.
